6 Advantages of Laser Cutting
Image credit: cammmetals.com
Laser cutting is one of the most commonly used technology in fabrication projects. The precision and speed provided by this technology cannot be found in any other type of metal cutting method. The following list explains why fabricators should, when possible, choose laser cutters for metals.
1. Shorter Lead Times
When fabricators use the right type of laser cutter, they can offer the fastest cutting speeds on the market. Although the best results are obtained on thin metal sheets, the technology can work pretty quickly on thicker metals too. Laser cutting positively affects also efficiency, as multiple parts can be programmed and cut at once.
2. Precision
No other cutting methods can compete with laser cutting when it comes to precision. Laser cutting can produce high quality parts and minimize the waste production. The characteristics make this technology particularly suitable for the aerospace and medical industries.
3. Energy Usage
Laser cutting technology uses less energy than any other cutting method during the fabrication process. This is an important feature to consider, both in terms of cost savings and environmental impact.
4. Consistency
The combination of laser cutting and CNC CAD/CAM technology ensures that the same cut can be repeated as many times as needed.
5. Versatility
Laser cutters work effectively on a wide range of materials. Moreover, multi-axes lasers allow fabricators to work on a wide range of projects.
6. Reduced Finishing Requirements
Laser cutters produce smooth edges that are free from burrs. This feature significantly reduces the need for finishing steps.
