Bill D
- Apr 1, 2004
- Modesto, CA USA
Some milling vices have a slot with a piece of key stock screwed onto the bottom. this is used to locate the vice on a milling table so it is parallel to the table. my question is how accurate is this method on it's own with out a little checking and tweaking with each relocation.
Is this accuracy good enough for most small workpieces or is just intended as a guide and it has to indicated in each time it is moved.
Bill D.
Bill D.
