Dope
- Jan 16, 2016
Mitutoyo 12"&18" HDS Absolute Digimatic height gages & Starrett 12x8x2 granite plates
I have a whole bunch of 12" and 18" versions of these Mitutoyo HDS Absolute Digimatic height gages. Code 570-312 (Model HSD-H12"C) and 570-313 (Model HSD-H18"C). The plates are Starrett 12x8x2" pink granite, Inspection Grade A with one Toolroom Grade B, all have mounting holes for an indicator or height gage.
These height gages have all been tested for smooth articulation throughout the full range of motion. I have also tested measuring and repeatability against a gage block on a granite plate. They all include a carbide-tipped scribe. Some have holes for mounting to a surface plate, this will be noted in the individual item descriptions below. If shipping is desired, the height gages will be shipped in heavy-duty .175" wall cardboard tubes for protection. Dimensions are about 26"x6"x6" (15lbs) for the 12" models and 32"x9"x6" (20lbs) for the 18" models, if you want to calculate UPS Ground shipping charges from 46041. Granite plates can be shipped USPS flat rate medium for $16. If by chance I have missed something, and you are unhappy with your purchase, I will issue a full refund.
Message me your offers and/or if you need me to calculate shipping for you. Deals for multiple/all height gages and granite plates will also be considered.
Individual descriptions and prices:
12" models:
1-Nearly flawless condition, has mounting hole. $425
2-Chipped paint on the base, has mounting hole. $375
3-Nearly flawless condition, has mounting hole. $425
4-Minor chips in paint on base, has mounting hole. $400
5-Nearly flawless condition, has mounting hole. $425
6-Nearly flawless condition, has mounting hole. $425
7-Nearly flawless condition, has mounting hole. $425
8-Brand new, no mounting hole. $525
9-Nearly flawless condition, has mounting hole. $425
10-Chipped paint on the base, has mounting hole. There are some light pits/scratches at the top of the column (see last picture). This results in a sometimes glitched displayed readout for the last 2.5 inches of travel or so. As a result, this only works flawlessly as a 10" or so height gage. $250
11-Nearly flawless condition, has mounting hole. $425
12-Brand new, no mounting hole. $525
13-Nearly flawless condition, has mounting hole. $425
14-Nearly flawless condition, has mounting hole. $425
15-New but please note that there is an etching on the backside. This was still in the original plastic bag but it had been opened to do the etching. It was still sitting on the shelf, in the bag and had never been used from what I can tell. $500
16-Nearly flawless condition, has mounting hole. $425
17-Chipped paint on the base, has mounting hole. Display has a cloudy spot that doesn't affect viewing. See additional pictures. $350
18" models:
18-Chipped paint on the base, has mounting hole. $475
19-Nearly flawless condition, has mounting hole. $525
20-Nearly flawless condition, no mounting hole. $525
21-New but please note that there is an etching on the backside. This was still in the original plastic bag but it had been opened to do the etching. It was still sitting on the shelf, in the bag and had never been used from what I can tell. $625
12"x8"x2" granite plates:
1-Grade A with some chipped edges and a rough spot where inspection had been done previously. $80
2-Grade A with some chipped edges and a rough spot where inspection had been done previously. $80
3-Grade A with no chipped edges, rough spot where inspection had been done previously. $90
4-Grade A with no chipped edges, rough spot where inspection had been done previously. $90
5-Grade B with no chipped edges or roughness that I can see. Seems to be pretty much perfect. $120
6-Grade A with no chipped edges, rough spot where inspection had been done previously. $90
7-Grade A with one tiny chip on an edge and a lightly speckled worn area. $100
This photo album has multiple pictures of every height gage and granite plate. The number is written on the table next to the item, or it is noted in the description for the picture itself. Mitutoyo Height Gages and Starrett Granite Blocks - Album on Imgur I didn't want to spam 100+ pictures in this thread
Please feel free to contact me for more pictures, close-ups or even video of a specific item and I will provide it to you.
12" models:
18" models:
