0t--cutting up the cutter---USCG Healy
JHOLLAND1
Oct 8, 2005
western washington state
USCG icebreaker Healy is the newer of the two icebreakers presently in US service
in 2020 fire destroyed one of the two main propulsion ac motors-- section of double hull was removed
allowing extraction and replacement of the 15 megawatt 3 phase motor
video
DDoug
Oct 18, 2005
NW Pa
As the veterinarians call preforming a "C" section on a animal...."Taking it out the side"....:D
FamilyTradition
Feb 24, 2018
Greenfield, Mass
Very cool. My brother does lots of work on small boats (under 30ft length), and it is the same thing - he has had to cut sections out to replace or repair engines.
I wonder why they don't design them to be more easily serviced/for replacement of major components.
neilho
Mar 23, 2006
Vershire, Vermont
Cool! I especially liked the hydraulic cylinders inching the load in and out of the ship. Push/pull, pull a pin, extend/retract the cylinder, drop the pin in, do it again.
And all that happened in only two days. I do have to wonder about how they got access to cut and reweld all that bracing between hulls.
DDoug
Oct 18, 2005
NW Pa
Bolted connections require much more time/materials to make, add weight, and can leak.
Welding is very predictable, strong, and repairable.
