10 inch apron, traverse wheel, bushing part number
lost512
Jun 2, 2023
Looking for part number for a ten “ a model 1950 ‘s , apron travers wheel bushing on
kitno455
Jul 9, 2010
Virginia, USA
AFAIK, there is no bushing. The handwheel shaft runs in a bore in the cast iron. So do all the other shafts in the apron. The only exception would be the worm, it sometimes has a replaceable bushing.
swells
Dec 29, 2004
Indiana
Here's the 10L and higher apron assembly drawing (you don't say what 10" you are talking about). Please point out what bushing you are referring to.
That's a common wear point on a "well-used" lathe, many times the wick will eventually get cut by the gears if the wick wire holder service was not preformed. The best long-term solution after boring and sleeving the apron is to install a Gits oil cup for normal oiling and not worry about running the wick way down to the bottom of the apron.
