peterh5322
- Dec 15, 2002
- Monterey Bay, California
As previously reported Here a 60/53 transposer using end gears "by threes" from 24 T to 42 T is an excellent choice.
"By threes" from 24 T would mean end gears of 24, 27, 30, 33, 36, 39 and 42 T would normally be required.
However, 39 T gives no usable pitches, and in order to cover one standard pitch a 34 T end gear must be added, and in order to cover two other standard pitches a 38 T end gear must be added, for a total of eight end gears including the standard 30 T end gear, meaning seven new end gears must be made.
The basic error is 0.016 percent (15 of the 21 standard and 23 standard/model-maker's pitches), with an average error over all standard/model-maker's pitches of 0.054 percent.
The results are as follows ...
6.0mm ... 36 T end gear ... 0.016 percent error
5.5mm ... 33 T end gear ... 0.016 percent error
5.0mm ... 30 T end gear ... 0.016 percent error
4.5mm ... 27 T end gear ... 0.016 percent error
4.0mm ... 24 T end gear ... 0.016 percent error
3.5mm ... 42 T end gear ... 0.016 percent error
3.0mm ... 36 T end gear ... 0.016 percent error
2.5mm ... 30 T end gear ... 0.016 percent error
2.0mm ... 24 T end gear ... 0.016 percent error
1.75mm ... 42 T end gear ... 0.016 percent error
1.5mm ... 36 T end gear ... 0.016 percent error
1.25mm ... 30 T end gear ... 0.016 percent error
1.0mm ... 24 T end gear ... 0.016 percent error
0.8mm ... 30 T end gear ... -0.157 percent error
0.7mm ... 38 T end gear ... 0.062 percent error (Note: special end gear)
0.75mm ... 36 T end gear ... 0.016 percent error
0.6mm ... 30 T end gear ... -0.157 percent error
0.5mm ... 24 T end gear ... 0.016 percent error
0.45mm ... 34 T end gear ... 0.582 percent error (Note: special end gear)
0.4mm ... 30 T end gear ... -0.157 percent error
0.35mm ... 38 T end gear ... 0.062 percent error (Note: special end gear)
0.3mm ... 30 T end gear ... -0.157 percent error (Note: model-maker's pitch)
0.25mm ... 27 T end gear ... -0.464 percent error (Note: model-maker's pitch)
