Will McRay
- Dec 31, 2017
I have a 1947 10EE and all works fine except I have developed an issue with the spindle speed. When the spindle speed is turn down to say 300-500 rpm and the spindle is stopped. When I turn the spindle back on, the speed is now at its lowest rpm. I then have to increase the speed via the knob and around 1000 rpm the spindle speed will jump to that speed. From there I can control the rpm as you normally would. This only happens after stopping the spindle while in a low rpm. If the rpm was say 700 rpm and stopped then started, it would start just fine back at 700 rpm.
Not sure if motor brushes could cause this or if the rheostat is bad.
Anyone experienced this before or have any recommendations?
Thank you all in advance.
Will
Will
