ee_chris
- Apr 9, 2003
- Derwood, MD
I just replaced the end-gear (idler?) bearings on my 1946 square-dial 10ee, and I thought I’d post what I did to help anyone needing to do the same. I’ve read about other solutions for replacing the hard-to-source original bearings, like cutting your own snap-ring grooves, but my solution was pretty painless.
I *think* the gears are PNs EE2863 and EE2865 on sheet 142. They are located under a cover (EE2858) behind the spindle drive belts. The cover can be removed with the belts in place if needed. The compartment is basically dry. Teeth on the gears in the compartment are lubricated by oil riding up the gear-train from the sump at the very bottom (well below the cover), but the bearings themselves are shielded and permanently lubricated (grease).
I noticed some noise coming from the area when configured for threading, more than my 1947 10ee. When I pulled the two gears out the bearings didn’t feel smooth so I decided to replace them. After pressing them out they loosened up, but I suspect whatever grease or oil is inside was dried out and no longer doing its job.
There are two bearings used in each gear, Monarch PN EE2407, which are New Departure “C 487505 V”. New Departure is long gone, but based on a catalog I found online, the dimensions match a Timken/Fafnir 205KDDG *except* that the New Departure bearings have an extended inner race, while the modern bearings have a flush inner race. I think the ND PN prefix or suffix might indicate that or that they are a special version. I wasn't able to find an exact replacement that had both the snap ring groove and extended inner race. They are probably available, but the ones without the extended inner race are readily available on eBay. The snap ring groove offset relative to the outer race appears identical, along with the included snap ring. In this pic the New Departure with the extended inner race is on the right, Timken replacement on the left.
For each gear, the inner races are on a spacer (EE2872), which is retained on a mounting stud on the “banjo” (EE3126) with a hardened washer (EE1088) and a nut (426-3). The hub can be easily pressed out using an appropriately sized deep socket. The outer races are a light press fit into the bore on each gear, one from each side, and there is a gap between them. They can be removed by taking off one snap ring, and pressing the bearing on that side through the gear and out the other side along with the second bearing.
Since the new bearings I selected don’t have an extended inner race, shims are required on each side of the inner races to center the gear on the spacer. The height from the shoulder to the end of my spacers was about 1.341”, versus 1.275” measuring outside the inner races in the installed new bearings. So there was about 0.066" to make up, split between the two sides. I ended up needing a little more than this.
I bought some packs of shims from McMaster that are 0.031” (nominal) and 0.002” thick. I ended up using one thick and two thin behind each gear, and one thick and two thin in front to match the height of the hub. With the hardened washer and nut installed, the shims can be rotated, but there isn’t any axial slop and the inner races don’t turn. The shims were McMaster PNs 3088A436 and 3088A166. These are 1”ID but fit the 25mm OD spacer. The 0.031" shims worked better than the metric-series options.
The old cover gasket was trashed and ineffective, so I made a new one out of 1/64” Garlock 3000 and glued it to the cover with Gasgacinch. It should be removable for access without ruining the gasket.
The end result was that replacing the bearings quieted the gear train down quite a bit.
One question: Is the location of the end gear “banjo” (EE3126) adjustable? If so, how do you properly set the clearance on the gear teeth?
Chris
Chris
