10L QC Gearbox Bushing Question (Single Tumbler)
opsoff1
May 23, 2012
MA
More updates..
The process of cleaning and getting all the muck out is extensive. It seems and has become a familiar path that Mr. Murphy clearly lives close by. The more I di into this the more issues I am finding which in turn generate more questions - like a self licking lollipop.
I had to drill and re-tap the oil passage screws on each end of the clutch shaft - couldn't get those original screw out no matter what. Glad I did in that the oiled passages were really clogged.
I was able to turn the end of each shaft (clutch gear & cone gear) for the new bronze bearings and also make both bearings that fit perfectly. I cut the new keyways with a broach for the felts. When I compared the new bearings to the old ones (an I am assuming the old ones were original to the machine) I dawned on me that when I install them in the housing - if I mimic the orientation of the old bearings - the keyway for one oiler felt does not align with the oil passage hole & Gits cover. The other ones does. Is this a mistake? Should they align so the lubrication flows directly to the felt keeping the shaft and bearing lubricated? Or if not - should I machine in a small oil groove on the ID of that bushing to allow the felt to get oil from the passage/Git cover?
kitno455
Jul 9, 2010
Virginia, USA
I would do whatever it takes to get oil to that felt. In the past, when I have an assembly that I cannot align for some reason, I have cut a groove in the OD of the bearing, and added oil ports into that channel. You probably don't need anything that drastic.
