13" South Bend lathe Quick Change Tumbler Lever Question
dwall174
Sep 14, 2011
Southeast MI.
I'm currently working on rebuilding a 13" South Bend turret lathe & I've came across a possible issue with the tumbler levers. The castings are worn/elongated where the tumbler shaft runs through the casting.
I'm wondering if there may be an old print/drawing of these castings?
Knowing the center-to-center dimension of the tumbler shaft & the tumbler gear, I could always bore it out & install a bushing.
Pic. with gears meshed together gives me an educated guess, but a print or drawing with the dimensions would help out if there was one out there.
Doug
johnoder
Jul 16, 2004
Houston, TX USA
I'd be counting teeth, coming up with a pitch dia for each gear and half of the two pitch dias added together and divided by two is the center distance
in the process you will also come up with Diametral pitch of those gears
Example...
32 teeth and 2.125 OD
Add TWO to the two count
Example:
32 plus 2 = 34
34 divided by 2.125 = 16 DP
32 teeth of 16 DP has a pitch dia of 32 divided by 16 = 2.000"
You could see if you are close that way as compared to your pictured way
dwall174
Sep 14, 2011
Southeast MI.
Never really working with gears that much, all that gear terminology basically just confuses me!
Trying to follow your example given, I'm coming up with 12 for the Diametral pitch, which I don't think is correct? From other remarks about the change gears on a 13" South Bend I believe they are 16 DP with a 14.5 pressure angle?
The large gear has 32 teeth & a outside dia. of 2.840"(outer edge of teeth)
The small gear has 20 teeth & a outside dia. of 1.840"(outer edge of teeth)
The depth in-between each gear/tooth is approx. 0.200" deep.
Doug
johnoder
Jul 16, 2004
Houston, TX USA
Good work - 12 DP it is ( 11.95 is close enough to say 12)
So,, PD for 32 would be 2.6666 and PD for 20 would be 1.666 (find PD by dividing tooth count by 12)
Add those together and you have 4.333 and half of 4.3333 is 2.166 - which is the center distance you would have for the pair
You can see in your first photo you are only ten thou different than my way - so a real good way to check
A thing to keep in mind is the gears are not metal to metal in assembly. If your first photo has them touching each other there is part of the ten thou
dwall174
Sep 14, 2011
Southeast MI.
I knew that they're not metal to metal in assembly, but I was trying to get a rough idea of the center-to-center dimension. In the casting's current elongated condition there's a lot of play on the tumbler shaft. Getting it back close to the original dimensions should help in the engagement of the change gears.
According to the serial # "https://www.practicalmachinist.com/...mbers-wanted-128483/index129.html#post3846990" it looks like this lathe was made in 1961~62. At 60 years old, I'm guessing there's also some wear to the original gears OD.
I plan to replace at least one of the tumbler gears, which looks to have been repaired! Probably do to the gears not engaging properly do to the elongation of the lever castings.
Doug
SBLatheman
Jul 7, 2008
South Bend, In
Doug
I have some new gears, and probably can get the correct center distance for you.
Send me an email
Ted
[email protected]
dwall174
Sep 14, 2011
Southeast MI.
Bringing this old post of mine back up, still trying to find the correct C/L distance of the two holes!
If anyone happens to currently have a 13" double tumbler gearbox disassembled, it would be great to know the correct C/L distance!
Send me an email
Ted
[email protected]
Ted sending you an email.
Doug
Joe Henderson
May 21, 2006
Blooming Grove, Texas
There will be part of that casting that is not worn and is still factory. You can set it up to that part and either line bore it or bore it out until you clean it up. Then make a brass or bronze bushing to fit.
dwall174
Sep 14, 2011
Southeast MI.
Ted reconfirmed confirmed the 2.166" C/L distance, his measurement was 2.167"
The local machinist I had do the work for me was also able to come up with a 5-degree angle between the plunger C/L & the 1/2 hole for the tumbler gear shaft.
The machinist made a jig to locate the arm for boring it out, Here's a pic of the jig/fixture for his set-up.
Using all the above information he was able to mathematically figure out the X.& Y. location to bore out the arms.
Both arms bored out to 1.188" so I should be able to use a standard bronze bushings.
Doug
