magno_grail
- May 29, 2014
- ca, US
Pulled the I/O board to fix a different problem now it has the 149 spindle turning error and will not go into low gear. Everything else is working and I can slow the spindle using the keyboard. The spindle at speed signal never worked and the work around was to change the time delay to continue (Parameter 70).
Noted the Spindle Not Stopped (SP SP*) and Spindle Not at Speed (SP AT*) are always both zero under Diagnostics. I would expect the SP SP* to be 1 whilst the spindle is running and the SP AT* to be 1 until the spindle is to speed then 0. Is this correct?
Diagnostics show the spindle is in high gear. The SP High and SP Low LEDs in the I/O board never light. It already is in high gear so that one is not expected.
M41 gives the same 149 alarm.
