Froneck
- Dec 4, 2010
- McClure, PA 17059
Up-Date
Ground 55° tool with sharp point, didn't try to radius it. Machined a blank .468" with a .412" pilot. Used the Starrett protractor set to 27.5° and used the chuck face that I know is square with no run-out to position the tool that is on center height. Threaded the blank using the nut as my gauge. Threaded until the tip touched the pilot and checked fit. continued but increasing depth .001 thread depth knowing the the sharp point would have to go deeper. Nut finally started but 1 turn, cut another .001" nut went on more. Continued until OD was reduced to .465" Nut will only go on 3 turns then stop indicating pitch is wrong. Checked with thread gauge and 18TPI fits perfect! Checked the Delrin I threaded with the nut and it too fits the 18TPI gauge perfect.Checked Delrinr again with 1.5mm thread gauge and still the same after 10 threads the alignment is at least .75mm off! Colored the screw threads with Magic Marker, rub off is at the leading edge of the 3rd thread. Indicating he 18TPI is not enough lead. So it must be 1.5mm though the Delrin threaded with the nut is 18TPI! I guess the best thing is to get a 12mm X 1.5mm tap. Any other suggestions?
