17-4 machining - carbide vs. cobalt
specfab
May 28, 2005
AZ
I am selecting either H900 or H1150 grade 17-4 to make some harder wear parts to replace a 303 piece. H900 runs about Rc 40, H1150 is around Rc 28. I'm wondering whether the difference between the two hardness specs means a complete change of tooling required. I need to make some disks about 1" dia. with a precision center bore and a few small holes, and I'm hoping that carbide drills are not required. It's small qty work on my own product, so I have some flexibility based on all the factors involved. Any guidance appreciated.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
Either hardness you'll be fine with quality cobalt drills. I tend to use them rather than carbide when I have the option. It sounds like limited cutting time, so have at it.
Zeuserdoo
Aug 31, 2015
The Moridor
Cobalt will work fine for what you are doing. The work where carbide drills are worth the price is when you are drilling hundreds or thousands of holes.
BugRobotics
Jun 22, 2015
Denver, CO
I prefer cobalt drills in stainless where I have a limited run and don't have the feed/speed dialed in as the cobalt is a bit more forgiving.
specfab
May 28, 2005
AZ
Thanks, all -- made the parts, using cobalt drills and carbide inserts on lathe work, except for a couple of small (.062) holes through the parts, which are 1/16" thk. Looks like after 2 holes through, a standard HSS drill (what I had on hand) gets the outside corners of the cutting edge worn away, and they are essentially useless for completing a center-drilled hole location. It surprised me after the first part, where the drill seemed to be fine. Went though a few drills for a few parts. Probably need to look more carefully at speed/feed for that size drill. I love that H900 stuff, beautiful finish on the turning and part-off.
trevj
May 17, 2005
Interior British Columbia
If I were to guess, I'd say i have made well in excess of my body weight in 17-4PH shims and bushings, mostly with HSS tooling and whatever drills were on sale when the supply guy ordered. It's not really 'that' hard, or miserable to machine.
specfab
May 28, 2005
AZ
I agree -- just requires a little care. Does seem like cobalt works better than standard HSS, but my sample size is small.
