I recently acquired my first lathe, a 1940 Sundstrand drive Monarch 10ee. I am in the process of cleaning and inspecting it and have several questions I am hoping to find answers to.
First a picture of the lathe shortly after I received it. Just cleaned the bulk of the chips/oil off of it and wiped it down.
As I have disassembled the cross slide / carriage assembly I would like to replace all of the felt wipers. I can measure the ones I have removed but I am concerned that they are undersized due to years of compressed use. Has anyone drawn in CAD the correct dimensions for the wipers on a Sundstrand drive 10EE? I saw searching on the forum here that the replacement wipers sold by Monarch did not fit the Sundstrand lathe of another member so I will be making my own. Is F1 or F10 felt the correct felt from McMaster?
The Tachometer glass is cracked on my lathe. Does anyone know a source for a replacement glass?
I am getting a small amount of oil seepage on this inside corner here. Is this a common problem? Is there a gasket somewhere I should be looking to replace?
This looks to be the original oil cap? I only have one of these and the rest are obviously home made and one is missing. Are these available anywhere? or are the standard oil cup with the hinged cap the best replacement option currently?
When I got the lather the flat belt and all of its pulleys were completely covered in oil. It looks like this pulley is the culprit. I will need to pull the pulley and replace whatever shaft seal is there?
I do not have the lathe running currently, I have removed the Sundstrand drive and the motor is in the shop for a rewind. In the meantime I have connected a small motor up to the sundstrand and verified its functionality although I have leaks at all three of the acorn style pressure relief caps that will need to be addressed. It looks like copper washers on there currently. I will replace the washers but should a gasket or gasket material be added to help seal?
I would just like to confirm what I have found for replacing the fluids, Mobil Vactra #2 for the ways, Mobile DTE Medium heavy for the gearbox, the spindle is Mobile DTE light for the 2 outside reservoirs and Mobile DTE medium heavy for the center reservoir? The Sundstrand drive reservoir is also Mobil DTE Medium Heavy?
I have searched online but I cannot find a copy of the Monarch manual that is for the Sundstrand drive model. If anyone has a copy that they could share please let me know. I have the 6 page Sundstrand manual but not the Monarch manual.
I am missing the brass ID tag off the front of the lathe. Are reproductions available anywhere?
Thanks for any help.
