1942 10ee MG speed and voltage issues
labeeman
Mar 29, 2016
If you were getting 350 VDC on the armature you would be getting more than 1K RPM on the motor with full field.
Cal Haines
Sep 19, 2002
Tucson, AZ
Well, that was it. With cardboard between the DB contacts, it goes to full speed. I'll check into it's coil next.
Is the 350 armature max voltage a concern? Other posts indicate 240 being the max.
You can run without the DB relay. Dynamic braking will still work, but when you're above base speed, it doesn't work as well, since the field won't be a maximum. Just take the relay out until you figure out what's wrong with it. I don't know if Bill (9100) is still interested in rewinding DB coils; you can also do it yourself, using the 10EE to do the winding. There are several threads here that explain coil winding in great detail.
350 VDC is quite high for the armature voltage. A number of people have reported armature voltages around 300 VDC, but 350 is a new high. My 1943 MG machine reads about 300 VDC. But I've never put a scope on it to see if some of that might be transients. If you can borrow an old school analog meter, it will be less susceptible to switching transients created by the commutator.
You said in your first post that you have 128 VDC coming from the exciter. It should be putting out 115 VDC. If it's over voltage, the output of the generator will be high as well. You can adjust the the exciter's output by increasing the resistance of the series resistor in the exciter's shunt field circuit. The resistor is located in the generator's end bell.
Just to clarify, the DB relay DOES NOT control dynamic braking. I've long felt that it's mislabeled: I would have called it the "Full Field" relay. The dynamic braking resistor is actually controlled by the two normally closed contacts, one on the bottom of the F and one on the R contactor. When they are both closed (i.e. F and R are open), the dynamic braking resistors are connected across the spindle motor's armature. All the DB relay does is make sure that the spindle motor has full field, so that dynamic braking works most effectively.
Cal
9100
Nov 1, 2004
Webster Groves, MO
I have not rewound one of those coils but I probably can. Before doing anything rash, see if there is a spring on the relay. I have pictures of the panels I worked on but I can't tell from them where the spring is. Probably at the bottom of the relay as it sits on the panel. If the spring is missing, the relay will close on a small current, I. E. all the time. Unless someone has a sample to copy, you may have to experiment, but fortunately getting it wrong won't burn anything up, the lathe just will not operate properly.
Bill
FortyFive
Aug 29, 2018
Cal
That helps in understanding the dynamic braking. I may just run without it for now like you suggested. I don't want the higher voltages to damage anything over time. If they are in fact that high. I'll try to get ahold of a better meter. I looked at the adjustable resistor you mentioned. It would have made sense that a previous owner could have lowered its resistance to try to get more speed because of the relay issue. Doesn't seem to be the case though. Visually, the wiper is at about 3/4 of max resistance. Without disconnecting anything it measured 121 ohms. Then I disconnected the wires at A2 (information in one of your other posts) to isolate. Then it measured 155 ohms, which seems inline with others.
FortyFive
Aug 29, 2018
Bill
There is a spring at the bottom of the relay, but it is a normally closed relay.
9100
Nov 1, 2004
Webster Groves, MO
OK, but I am puzzled. It seems that it would have to be normally open unless running voltage kept it energized. I have specs for three Monarch relay coils in my archives, round dial contactor coils (forward and reverse contactors), braking relay and anti plugging coils. I remember making a main contactor coil but the others are probably for square dials. The anti plugging coil is 24,750 turns of #37 wire. Takes a while to wind.
Cal, if you have a round dial schematic digitized, I would appreciate having one. I have square dial and modular drawings.
Bill
Cal Haines
Sep 19, 2002
Tucson, AZ
Bill
That's how it works. The DB relay's coil is energized whenever the F or R contactor are closed, opening the contacts. It has to be energized to allow field weakening to work. As soon as the F or R open, DB's normally-closed contacts close, bypassing the field control rheostat and providing full field to the spindle motor. FortyFive's panel uses a Struthers-Dunn 3334 relay for the DB relay. Later panels also used an SD 3334 relay for the AP relay.
There were about a dozen different round-dial panels. I'll send you the common diagrams.
Cal
kevin johnson
Feb 14, 2008
lone jack mo
I am reviving this thread because it is a godsend for me. I got tapped to look at a friend of a friend’s 10EE that had quit accelerating with when the field voltage was supposed to decrease.
A piece of plastic in the DB contacts fixed that. The DB coil has loose copper strands sticking out of the wrapping. I did not ring the coil because bypassing it seemed to work. That and it didn’t look correct, I think tells the story.
I am looking for advice on a replacement relay.
We also found that when increasing the speed further up, the field relay would start to go on in and out, almost chattering. I have no experience with these but that doesn’t seem correct.
Thanks in advance for any help.
Kevin
rke[pler
Feb 19, 2002
Peralta, NM USA
If I recall correctly that's a Struthers Dunn CX3334-A relay (as is the AP relay), you might contact them and see if they have the specs and/or a suitable replacement. At the same time the DB and FA relay coils are fed through the big-ass resistors on the DC panel and failure in the resistors can cause problems similar to those you're experiencing with the FA relay.
Maybe contact the user 9100 and see what he has.
