1942 10EE Round Dial Apron Oiling feed to Carriage Connection Issue
Hobby Racer
Apr 18, 2015
Can someone tell me if this is a factory connection or is it some previous owner's attempt at a repair?
I'm trying to join my apron to the carriage and the oil supply line from the apron does not appear to connect, at least not in a way that would seal correctly. When disassembling this months ago I did not pay enough attention to the connection so I'm not sure if it was every right.
Here is pic of the apron to carriage connection with the threading dial portion removed so you can see the oiling connections. Note: the pic is upside as the carriage is on the bench.
Here is close up of that strange piece on the end of the tubing. It appears to be an extension that is crimped onto the 5/32" tubing. The small diameter at the end matches the tubing diameter.
There was a traditional Bushing on the end that was screwed into the oiling "T". Not sure that was sealed as there is no crush sleeve and the bushing is a slip fit onto the extension.
Any ideas on how to join this line back to the "T" would be appreciated. I would prefer not to have to snake a new copper line back through the carriage if I can avoid it.
Cal Haines
Sep 19, 2002
Tucson, AZ
It's not under a lot of pressure, so maybe an O-ring will work. I was able to get mine to seal up using a short piece of tubing in place of the sleeve:
Maybe you can bore out the back part of the bushing to allow it to slide back enough for an O-ring or crush sleeve?
Cal Haines
Sep 19, 2002
Tucson, AZ
Maybe go back before the bend and splice on a longer piece of tubing? I don't know if HVAC suppliers have a sleeve fitting that allows two lengths of tubing to be joined. (I'm thinking of the sweat fittings that you use to join two lengths of copper pipe.)
Cal Haines
Sep 19, 2002
Tucson, AZ
McMaster has brass tubing with ~5/32" ID. A length of that could be used to make a sleeve to join to sections of tubing: link
Is your tubing made of copper or copper-plated steel?
Hobby Racer
Apr 18, 2015
It's not magnetic so I'm assuming it's pure copper. Sweating is definitely an option.
Seems like every time I need something from McMaster, the shipping cost twice as much as the small part I need!
rakort
Apr 27, 2011
Central Wisconsin
In my case that tube that supplied the carriage was janked. Yours looks to be in similar condition as mine. My recommendation is to dig that thing out of the carriage and replace it up to the manifold under the carriage. It is an intimidating process at first but not that bad as you might think and quite satisfying in the end. All those kinks and funk in the tube I'm sure won't serve you well. I've got pictures on my thread and many others not on the thread if that helps you! Go for it, dig it out, the right tubing is easy to work with.
Brian
Hobby Racer
Apr 18, 2015
I checked out your thread and your right. I've come this far, may as well do it right and dig out the line and replace it with new.
Why do they fill in the cavity in the cross feed nut area with a type of bondo filler?
rakort
Apr 27, 2011
Central Wisconsin
So I thought I posted this last night, but apparently that didn't work! Bijur is your friend for parts. Replace all the metering elements under the saddle and the other one or two in the system. Bijur can supply you with the tube and fittings as well. There are other "aftermarket" options as well.
rakort
Apr 27, 2011
Central Wisconsin
Again in my case, the tube was janked. It was actually replaced with a tube that was too small. At the connection points it never really sealed.
That bondo type filler I understand is melted sulfur IIRC. You can dig that out without too much work and replace it if you like with something like bondo. My tube in the cross feed area was also damaged and first replaced, then later repaired. It was a mess. I think the big issue is when it gets packed with chips during production then the chips wear on the tube. I dug all that crap out of there, replaced it with a properly sized copper tube, and skipped the "bondo" step as the tube set nicely in the groove and didn't appear to rubbing on anything it shouldn't I did have to get a bit forceful with the tube to "set it" into the groves.
rakort
Apr 27, 2011
Central Wisconsin
Here is what mine looked like in the cross slide area after the first round of cleaning......clearly patched with solder. Not sure how they actually got solder to stick!
Cal Haines
Sep 19, 2002
Tucson, AZ
Brian,
Can you post some photos that show the upper part of the channel for the tube?
It looks like the hardest part of the job would be getting the tubing through the vertical hole above the manifold. Maybe you can walk us through the steps involved in installing the tubing. Did you use any tools to bend the tubing for form it by hand?
Hobby Racer
Apr 18, 2015
Well it was a lot easier than I thought it would be. For those finding this post in the future here are the steps I went through to get it done.
No special tools need as the copper tubing is super flexible, just don't bend it more than needed to prevent work hardening and stress cracks. Once the old tube and originally packing is removed you can see that the passage ways are straight thru drilled holes.
The most difficult part is feeding the tube from one of the holes to the other inside the cavity where the cross slide nut runs. I made as large of a bend as possible and inched it thru little by little until it was as tight as I could get it by hand.
After you have it as close as you can by hand, gently tap it into it's final position with something soft. I used some pieces of soft pine.
And then finish the ends and your done! I did not bother to repack the cavity as everything clears the cross slide nut and is locked in place very well.
rakort
Apr 27, 2011
Central Wisconsin
Brian,
I think hobby racer covered it, let me know if you are looking for any more pixs. When you say upper part of the channel for the tube are you referring channel under the cross slide?
rakort
Apr 27, 2011
Central Wisconsin
Nice work, like I said it seems intimidating at first, but when you get into it is not that bad. A good cleaning and scraping out all that old Sulfer.
I did much the same with hand bending / forming the tube and persuading it into place and the final setting with some gently places blows with wood blocks. I did not set it with bondo or other such things.
Brian
View attachment 384002 View attachment 384003
View attachment 384004 View attachment 384005
View attachment 384007 View attachment 384008
Hobby Racer
Apr 18, 2015
Would it help to ease the vertical hole above the manifold so that you don't need such a tight bend?
Probably would help. I didn't think of that when I did mine. The copper is very forgiving and I now have great oil flow to the carriage after the line replacement and all new metering units.
