While awaiting divine revelation on the wheel motor bearings, an examination of the grinding spindle was made. The spindle is pretty much the heart of the grinder and if it is in poor condition it will show in the finish of the work piece. The spindle felt pretty good, but thick, congealed oil will hide a multitude of mechanical evils! All-in-all it is not that bad, but will need a little reconditioning to make it good as new; and now would be the time to do it.
I have to say I am not all that impressed with the spindle design. I do not mean the use of plain bearings, I can accept that as superior for its ability at that time to dampen out vibration given the rigidity of the machine; or more accurately, lack of rigidity. One thing machine tool builders have learned over the decades is in a quality machine, you can never have too much rigidity! No, my criticism is more practical to the general use of the machine. The placing of the main grinding wheel between the bearings (rather than overhung) certainly gives the wheel the best support and evenly distributes the load between both bearings. However it does mean that you have to partially disassemble the spindle to change out the wheel. The same apples if you want to change the spindle pulley for a different diameter (wheel speed). Removing the spindle from the wheel stand is a fairly simple operation (first picture). The clamps roughly match the spherical shape of the housing of the wheel spindle bushing, but only touch at three spherical contact points. Yet this aggravation of dismantling the spindle could have been avoided by using either a stone with a bore larger than the three inch, or change the bearing housing slightly so that the three inch bore could be threaded over it without disturbing it.
The second picture shows the quickly detachable spindle on the bench, sans-wheel. Perhaps Messrs. Brown & Sharpe expected any Tool Room worthy of the name to keep several assembled spindles on hand configured for different applications. $$$!
The third picture shows the right-hand end of the spindle. Shown from left to right the pulley flange, the wheel spindle bushing, and then the adjustment for the end-float. The larger hex nut at the end of the shaft screws up against a thrust washer to set the correct clearance and the small bolt jams against the end of the shaft and locks the adjustment. The book advises 0.003-0.005 inch clearance cold, which should diminish to 0.001 at operating temperature. Setting of the bearings is very much by feel; the manual says the bearings should be quite warm, but not hot. Not sure if that is in Fahrenheit or Centigrade! This applies to the radial clearance as well, which I will get to anon.
The fourth picture shows the mounting taper and hub (2 inch diameter) for the stone when used on the left-hand end of the spindle. This was not recommended for general use, except in certain circumstances when the wheel head compound was set at an angle and access with the primary wheel was not possible. Another occasion is when sharpening tools and cutters; the normal work head would be removed and a optional universal (work) head substituted on the left-hand end of the table (fifth picture). When using the left hand end of the spindle the wheel was limited to six inch diameter. The primary (central) stone could be up to 10 inch diameter but a mere 1/2 of an inch wide. Normally the hub for the left-hand stone would not be installed unless in use, when not the taper and thread on the spindle would be covered by a protective sleeve. We seem to be missing that ‘hubcap’, but it should not be hard to make a replica. A stone could also be mounted at the right-hand side of the wheel stand of the slightly larger #2, 3, and 4 Universal with the purchase of some optional equipment. The spindle on the #2-4 was more substantial and had vee-belt drive rather than the flat belt retained on the #1.
That is it for the number of attachments allowed, so in the next installment we shall delve into the interior of the spindle. Bet you cannot wait!
-Doug
