SeanShanny
- Nov 17, 2021
- Shaftsbury, Vermont
Folks,
Have the tailstock all figured out thanks to great info from you folks.
Pulling the apron off is next on the list. I have the end support bracket off and the feed rod pulled out. Next working on the feed screw and it has me stumped. I have removed the tapered pin by the quick change gearbox. I have loosed what appear to be 2 collars possible used to adjust end play or bearing preload but for the life of me I cannot figure out how to pull the feed screw off the machine. I believe there is a stub that goes into the gear box and the feed screw shaft fits into the sleeve and is pinned in place but I cannot figure out how to separate the two. Any words of wisdom would be appreciated. I am looking at bulletin 20 but am not seeing a solution. I also need to remove the other two rods, the clutch rod and the lead screw reverse lever and am scratching my head on those as well. I am guessing I have to remove some stuff off the end of those in the gearbox under the large cover. I am just being careful to not smack things to get them apart for fear of breaking something.
Also have question about the chasing dial as the bolt that holds it to the apron just spins around so I cannot remove the nut to take it off the apron. Threads are a bit munged on the end of the stuff the dial is on but the fact that the entire stuff is turning is a bit worrying.
Pictures are attached. First one show lead screw with taper pin out and collars loose, 2nd picture different angle. 3rd and 4th pictures are of chasing dial. My guess is the worm gear and stuff hanging off of it are not standard and there should be a simple cap bolt in its place.
Thanks
--sean
Thanks
--sean
