f66
- May 18, 2019
- Columbia Maryland
I have a SB 10 in the attached pictures with a 240 single phase motor. Have not used the lathe in over 60 days, before today has worked well. Today went to turn on and motor hums but will not turn, released belt, motor turns freely. Turned switch to on position and turned chuck/headstock. Motor then will run but is slow and rough.
With that as a lead in what are the possible causes for this condition? I would like to fix and not have to replace the motor. If replacement is recommended, Where is the best source for a direct replacement?
Thanks in advance. Frank
