evanthayer
- Jun 13, 2018
Junction Box Upgrade
My idea is to keep all of the wiring interconnects within the existing OEM junction box attached to the motor casing. I thought it would be better to have several components coming in and out of that box in the back of the lathe versus having multiple connections going into the drum-switch on the front of the lathe. In the end, I wished I had gone with something bigger as it is a really tight squeeze in there.
Unfortunately my j-box is missing a second 1/2" knockout for a cable connection. In the past I would have drilled this hole out but every time I try to drill a larger hole in sheet metal all heck breaks loose. It is not one of my favorite things to do.
So this time I tried something new for me: a wrench-driven knockout punch. Perhaps this is like the most obvious way to do this but I didn't know!
The punch assembly is off to the left there, with the j-box in the center scribed and center-punched for drilling the pilot hole.
Drilling the small pilot hole was no issue - it's the larger holes that suck in sheet metal. I threw the box in a small vise and leveled it up prior to poking the hole.
Assembling the punch tool through the pilot hole was very easy. I held the whole thing in a vise as I assumed the torque requirements were going to be high to get the hole punched. Turns out the wrench made short work of the hole and there was very little resistance.
Good and easy result. I'll be using this tool many times going forward.
