1976 FP3, my new mill
thanvg
Mar 3, 2015
You can try to thread the holes with M8. Start with a regular tap and then end with a broken one you did grind flush Or drill the M6 hole 8.5 mm for a couple of mm Insert a set screw in the threaded M6 hole and then push against that with a M8 bolt
BUT The bore of that ring is a acurate fit with the spindle and rest of the bore So does it run smooth after reinstalled ????
Let us know please :):D
Peter
That's similar to what I had thought Peter, I see no other way.
And, regarding reinstallation, my idea was to install the ring without bolting it down, put the quill in deep in its bore so as to align everything and then tighten the M6 screws.
One should, in principle, be able to pull that ring off in order to, e.g. replace the lock ring I guess....
BR,
Thanos
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
Unless my German fails me (wouldn't be surprised, it has been a while) it doesn't say you must not remove #2; it only says #2 doesn't need to be removed in order to remove the quill. For the former I think it would use the verb müßen instead.
AlfaGTA
Dec 13, 2002
Benicia California USA
The clamp ring is split on the bottom i believe....At the split there is an exposed edge of the cover.
I would try a seal puller like this:
The end is narrow, might need a little work, hook engages the edge of the cover piece and you can tap on the right angle end to get the cover moving....
Of course you should bathe the internal areas with your favorite brand of penetrating goop.....
One of my favorites is plain turpentine (Mineral spirits) Does an excellent job an breaking down old varnish and oil residue.
What ever you choose give it some time to work...That cover has been there for a long time...
Cheers Ross
Jan 15, 2005
The Netherlands
You might also try threading the holes as Peter suggested and using a slide hammer instead of pushing against an interior threaded hole. Probably safer.
Disagree on that one Hammer is a impact Always unsure of its outcome And you push against a setscrew insearted in the hole Did I forget to mention that??
thanvg
Mar 3, 2015
No, you mentioned this
Slide hammering it out wouldn't work with so little thread engagement
Jan 15, 2005
The Netherlands
Once more I disagree Darf nicht means may not
I can see why they say that because i think the hole was honed with the ring in place But perhaps on a machine used for 45 years it is not a argument any more
Peter
thanvg
Mar 3, 2015
'darf nicht' is 'not allowed' unless I am mistaken...
And in English:
I think they mean it, hahaha
Or, like I said earlier, they mean 'dont remove it if you want to remove the quill '
BR,
Thanos
thanvg
Mar 3, 2015
Cheers Ross
Kinda scared Ross to hit anything near those high precision surfaces ...
It's too much already I am trying to pull this ring at all...
BR,
Thanos
Ps: lock clamp is split at its top, where the lock screw bolts on
eKretz
Diamond; Mod Squad
Mar 27, 2005
No you didn't, but if you are turning the outside screw it can also turn the inner one, leading to possible mashing of the first thread on the smaller hole. Thread engagement is an issue whether you push or pull - the threads are the same length either way - and the pull will be with the thread static, not turning which will help prevent thread damage also. And I don't know about the rest of you but I can use a slide hammer gently also... No need to ram it as hard as you can in one fell swoop. If removal is necessary I'd probably try to rig up two opposite each other and gently pull a small amount at a time that way.
thanvg
Mar 3, 2015
Just came back from the workshop, quick update:
Details tomorrow, it's super late here...
BR,
Thanos
thanvg
Mar 3, 2015
Hi to all,
so, at first, following advice of a good friend, I tried to go conservatively and try to flush the dirt off. After spending 1-2 hrs with spray cans and compressed air I got sick of it, no actual progress. In hindsight, it was apparent why
Dirt was coming out very slowly, fit is tight there.
Here you can also see the hole shape. There is the counterbore for the screw head, there is a 7mm through hole and then there is the M6 thread in the main headstock casting. 7mm cried for M8x1 and that's what it got. No drama, using Peter's advice for the headless screws in the M6 thread (thanks Peter!) and it started coming out without real force, nice, slowly and satisfactorily. M6 headless screws had bottomed down so there was no chance they would be turned by the pushing screws and length was such that the female M6 thread was protected.
Behind the ring cover was the pic seen before with the lock clamp and after removing that one as well:
It is apparent that
- there was no way to flush this thing off from the outside
- there was no way that the lock clamp would work as smoothly as on my FP2 with all that crap in there.
Now it looks a bit better, but still some polishing to do:
And the parts before cleaning:
After cleaning the ring I did a test fit on the quill. It's the same, extremely tight fit as the one between the quill and the main casting bore.
I am pretty confident that, provided the fit, if all is cleaned, smooth and burr free, there is no way this ring can end up misaligned. There couldn't be a better installation guide that the quill itself.
But we'll have to see about that I guess...
BR,
Thanos
PS1. I am not sure if I'll go on and install everything back on or if I am going to wait for the Kluber to arrive in order to do the horizontal before installing it. I've always found it very difficult to install the horizontal quill on these machines (and this one is much heavier than the FP2's) and I would like to avoid doing it twice...
PS2. Can't compare slide hammering something like this out to using nice fine threads as pushers taking all the time you want and going in circles (or criss-cross) in order to do it evenly. You would need 4 slide hammers hanging horizontally from 3-4 mm of thread engagement and magic hands to use them.
eKretz
Diamond; Mod Squad
Mar 27, 2005
Very true. Getting 4 slide hammers (or even two) is much more of a pain in the rear than using pusher screws. Since you mentioned that the seated screws were bottomed out and couldn't go further in that pretty much removes my reservations about that method. Good work. That 3-4 mm of thread engagement is a little iffy, glad that it worked out for you. Before reassembly I might measure the fit between the two. You might find that it would only take a very small amount of heat on the housing to mate the parts easily. Or shrinking of the male part with some LN2.
Jan 15, 2005
The Netherlands
The fit of the part in the housing is not the issue It does not fit that tight IIRC It is the alignment of the bore in that part and the rest of the bore of the quill A couple of 0.001mm makes a difference between smooth and tight
Peter
eKretz
Diamond; Mod Squad
Mar 27, 2005
Ahh, so it is a slip fit on the pilot? I had assumed it was interference. Alignment would be better with a heat or shrink if that were the case, rather than pushing it in. Still might require some gentle persuasion as you mentioned though. Tight alignments are tricky. That's where we get the "At Assembly" notations, heh.
Jan 15, 2005
The Netherlands
It is excentric as you can see The sligtest rotational mistake will make it jam Only the M6 bolts in their 7mm hole align it But perhaps it is not much of a problem
Lets wait and see
Peter
