WazMan
- Jul 12, 2013
- San Diego North County, CA, USA
Hello PM'ers.
I'm 2nd owner of a 1986 DECKEL FP3NC w/DIALOG4 and know it's history as the original owner was my employer and I had used this machine when it was new. Other than a known "bad monitor" the machine would power up and all basic jogs functions were operational. The machine has been sitting without power for more than 7 years and I am now trying to bring it back on line. Other than a few lit LED's (see photos), the fan in the controller, and the table lamp - the machine is lifeless. As for power in: I am "not" using a convertor, just a straight utility hookup. Through the advise of knowledgeable members of this forum, I located and replaced the 3 sets of batteries but with no change. I've also checked the fuses that I've come across, but I can't say all of them because I am unaware of all their locations. [Note: Tool change pendant "is" connected to plug near X axis servo motor and all "E-Stops" are off.]
I've been advised to very carefully start checking transformer inputs and outputs (i.e.- Main step up, T1, T2, and T3), and upon doing so have found a few under voltages and will define the readings in a future post however I just made a few physical observations I feel may be relevant:
Upon switching main power on large cabinet to "On" position (-), I hear a click and found only one of five of what the manual calls "contactors" labeled "22E"AEG-SHO4, to have it's red switch positioned to the left (see photo). Is that the only one turning on? Upon depressing an emergency stop or cabinet switch to Off (O), the red switch returns to the right.
The second and more curious thing I found with the help of a friend with good hearing, was a high pitch squeal or hissing noise coming from the control cabinet. I liken it to the sound an oily air hose with a small crack in it would make. I was able to isolate the sound and it is definitely coming from the board marked: "VG13 NSV" and more specifically a small square (1 1/2" or so) copper wire wound, coil looking piece soldered to the board (see photo). I've never encountered anything like it before. Can't be good thing, right?
Thank you all in advance, I appreciate any and all feedback.
Regards, Adam [aka:WazMan]
p.s.-(props to Ross, Steve, & Rich)
