CrashGordon1
- Dec 28, 2019
Hey guys, I'm trying to pull my turret tonight on my qt10, it's an '86 with t2 control. I removed the 4 shcs from the black cover seen in the picture, and for the life of me can not seem to get the cover loose, trying to wedge a paint scraper behind it, put brass pins in the bolt holes to pry on, great big channel locks around it...I tried with the turret clamped and manually unclamped with the machine off, and on, checked the mechanical parts diagram and couldn't find anything that would be holding me up, it just wouldn't budge. If my memory serves me correctly this has to be removed to get to the spanner nut that holds the turret to the splined shaft as well as the screws in the O.D. tool pockets. Is there a step I'm missing or a better trick up someone's sleeve to remove this cover? I don't see any past threads with this problem which tells me I'm missing something or it's welded on there!
