S&B Precision
- Feb 5, 2021
Hi all,
So I got this 1997 Deckel Maho dmu50v last month, and I only just now got it to start. It took so long because the pendant RCU (mpg or handle) wasn't plugged in. Also the estop was twisted up, and my twist was just one too many . But last night, I got it started, reference returned, and levelled. I also decided it would be wise to run the spindle for about 2 hours to break it in proper, starting at 500rpm and getting it up eventually to 6k. I also jogged the axes around to check for any rough noises. I made the mistake of doing the same with the pendant (or mpg or handle) because, you know...I wanted to make sure it worked. It did for x, y and z, but for the one labeled 'IV' it alarmed out:
On the control panel, 4 is the c-axis, so I assumed 'IV' was also the C, and I did not pay attention to the direction I went. This pendant is also not the original, and I'm hoping the IV was wired to the b axis and I over-travelled it, and that is what needs to be fixed.
This morning, I am fresh, and I'm hopeful. but now the alarms are different:
Thank you so much for reading my book, and I am grateful for any help.
Shawn
- C68 missing motor current
- C50 setpoint updat too fast
- I05 Estop from machine tool
- E24 No axes movement allowed
- O23 MC data out of range
- E60 Ready signal axes low
- I05 Emergency stop from machine tool
- E01 Lubrication pressure switch low
Shawn
