I rediscovered this forum today and though it's not nearly as busy as 20 years ago I thought I would contribute with something I use on my lathe most every time I use it. At the time I was a complete newby when I restored and repainted my 10L lathe with help from this forum. I always wished it had the taper attachment option basically only for the cross slide lock. One evening I designed a simple one my self using the lathe and an Enco Mill Drill I also just finished modding up with this forum. It works as a lock but also you can put "drag" on it that really refines the cuts I found. I also fitted a simple Dial holder that give you a cross measurements. I did change the clamping rod to brass later to make it even smoother if I recall. I also made a common carriage lock w/dial. Here are the old 300 dpi photos that I found today and they are kind of self explanatory. The last 2 photos shows what 20 years of of garage hobbyist use looks like today.
