2021 TL-1 VPS coding issues
Duc
Aug 20, 2013
ABQ, NM
Ill admit off the bat Im new at lathe programming and trying to figure out two different issues Im having with my 2021 TL-1 lathe in regards to VPS programming using the shape creature. Machine is out of warranty and bought used with I think 26 hours on it.
1. Shape creator generates the scp file without the radius value for a line but includes the R. Copy of the text file that is generated. Radius should be .060
(PART DIMENSIONS X1.2500 Z0.0250)
G00 X1.2500 Z0.0250
G01 X0.0000 Z0.0000
G01 X0.2700 Z0.0000
G01 X0.4232 Z-0.1600
G01 X0.4232 Z-0.8900
G01 X0.4431 Z-0.9100
G01 X0.4431 Z-1.8900
G02 X0.4900 Z-1.9500 R
G01 X1.1600 Z-1.9500
G01 X1.2000 Z-1.9700
G01 X1.2000 Z-2.3500
2. The code is generated using the VPS OD profile removal cycle. The G71 roughing cycle is coming up with 339 multiple code error but not sure where the problem is. I did fill in the R0.060
O01000 (xxxxx)
(OD Profile Removal Cycles)
( SAFETY LINE BELOW )
G00 G54 G18 G40 G80 G97 G99
( TOOL = 1 / OFFSET = 1 )
( MAXIMUM SPINDLE RPM = 2500 )
( SURFACE SPEED SPEED = 250 )
( DEPTH PER PASS = 0.05 )
( WORK OFFSET = 54)
(OD STOCK REMOVAL CYCLE)
T101
G54
G50 S2500
G96 S250 M03
G00 Z0.025
M08
G00 X1.25 Z0.025
G71 P172 Q173 D0.05 U0.01 W0.010 F0.005
N172 G42 X0. Z0.025
G01 X0. Z0.
G01 X0.27 Z0.
G01 X0.4232 Z-0.16
G01 X0.4232 Z-0.89
G01 X0.4431 Z-0.91
G01 X0.4431 Z-1.89
G02 X0.49 Z-1.95 R0.06
G01 X1.16 Z-1.95
G01 X1.2 Z-1.97
G01 X1.2 Z-2.35
N173 G01 G40 X1.25 Z-2.35
G00 X1.25 Z0.025
M09
G00 G53 X0.
G00 Z14.2785 (SAFE TC POSITION)
M05
( END OF CYCLE )
M01
Probably something stupid that Im missing and I wonder if I need to see about a software update for the lathe.
What is the (XXXX) at the first line in there for. im wondering if its reading that as an X axis move.
Thought I had replied. I didnt put the name of the program in. I switched the G42 to G40 to get the program to run and made a final pass afterwards. I only had 40 small bolts to run for a welding fixture table.
