Jaxian
- Feb 24, 2013
- Santa Cruz
I have in my limited time moving from manual to CNC machining done almost all aluminum. Some other stuff but nothing in the stainless steel realm.
So I got a job to make a base for a tool for the prototype shop at a large company. They wanted stainless. I checked the feeds and speeds and was a bit shocked at how low they were listed in my generic charts and even the defaults of G Wizard.
I then read the thread in here on the 4340 machining and knew I had done things very wrong and am hoping you guys can give me some direction.
I have another job coming up to make 12 plates for a lumber company for one of their saws. Like 12" x 12" x 1". They want them out of stainless. More stainless jobs now seem to be coming out of the woodwork so I need to get much better at it than I am now.
Here is the setup. Machine is a Doosan DNM5700 12k. Here is the material they gave me. Was told 304L, seems to match what it says on it. Flame cut but was told they had a new "process" that would keep the heat affected zone very small. Not really an issue as I squared it up on the manual mill as I didn't have time to learn how to MDI it on the CNC.
The raw material, 304L I believe:
Very basic shape. Some slotting, a recessed area, chamfered edges.
Finished product:
This took, using my feeds 2hr 15min. This is, based on what I have seen here, WAY too long.
Now the feeds and speeds, DOC, I used and SFPM:
Spot drill with 4 flute spot/chamfer 3/8" HSS
450 rpm, 44SFPM, .0012FPT, 2ipm feed (this broke the tip off)
Drill 31/64" (.4836), carbide, 550rpm, 69SFPM, 2ipm, 0036ipr (this seemed to work, full retract, .120 peck, long stringy chips that wrapped around the drill. Made squeaky noises.)
Endmill IMCO 67215 1/2" 4fl carbide (Slots), 1635rpm, 214SFPM, 5.5ipm, .0008ipt, .0033FPR .100 DOC, full width slot, conventional milling, finish pass full depth like .020 radial around the slot. (tried slotting at 11ipm to start, exploded my first endmill, got real conservative after that. This job was due the next day, no time for experimenting. This took 1 hour.)
Endmill 3/4" 3fl carbide (circle), 1177rpm, 224SFPM, 4ipm, .0011ipt, .0034FPR, helical in 2*, .250 DOC, 2D adaptive .2 optimal load, climb mill, stepdown was .4 max. (I don't see a stepover number in Fusion360. This took 18 mins to rough alone.)
Chamfer bit 1/2" 4fl carbide, 1200rpm, 157SFPM, 4ipm, .0017ipt, .0033FPR, like .050 on slots, .100 on circle, .150 on edge, used multiple passes on edge. (at 60" for all plus 4 passes on the edge this took 10, 4, 38 minutes respectively)
Got the job done. Second 1/2" endmill looks worn. Didn't break anything else so delivered the job. No way I can slack like this doing a dozen 1" plates. Any help would be appreciated.
Downloaded IMCO S&F chart, numbers come out MUCH higher than the ones I exploded the endmill on so a little leery of trusting them. I have almost no stainless to test on but I did find a few drops at the machinery place to mess with. I need to up my game a lot to get with the program. Thanks guys.
Paul B.
EDIT: Was running lots of flood coolant.
Finished product:
Paul B.
