3d models for free
AndyBuga
New member
I, frankly, did not figure out how it is safe for users to add files. If you could suggest a method, or perhaps another format, I would be grateful.
Milland
Active member
Andy, if this is legit and you have real solid models to share, there are websites devoted to allowing uploads of the actual files, not ZIPs. Here's a list of some:
https://all3dp.com/1/free-3d-models-download-best-sites-3d-archive-3d/
If you find a site you like you can link your uploads here as the actual file type. But ZIP files can be used for nefarious purposes, and shouldn't be linked to here without some rock-solid way to vet it.
AndyBuga
New member
Looks like my father:rolleyes5: In fact, can you tell me a good method to lay out the STL? It would be a bit frustrating to post a dozen more models and then get banned from the forum for spamming. I wrote it too late, thanks...I will freeze the topic and redo the posts, responding to your recommendations!
Milland
Active member
See my post #8.
AndyBuga
New member
Sorry for the stupid question, but can you tell me how to edit the thread? I wanted to temporarily remove the ZIP links, I can't edit the first post of the thread.
Milland
Active member
There's a time limit on ability to edit, not sure how long it is but around 4hrs or so. The moderator for CAD-CAM is Milacron, I've emailed him asking to remove the link in the first post.
Ishira
New member
You do excellent work, Andy! I'm a big fan of jewelry, and your designs are beautiful. If I had the means to have it produced I'd commission you for a model.
AndyBuga
New member
Thank You and good luck with!:) Alas, i have some models to share here, but no time because work. If moderator will approve the thread, i will share some models soon.
AndyBuga
New member
Link to my GoogleDrive: 302 Moved
There are 2 .stl and 3 .jpg files inside. I hope, it's safety way to downloading. Have a nice time:)
AndyBuga
New member
Link to download STL: 302 Moved
Link to STL: 302 Moved
I thought it would be a couple, because of the same flower in the design.
