5axis clamp not released error Millplusit DMG DMU 60
prinz96
Nov 12, 2022
Hello,
I need a help with an error on one of my machines Millplusit DMG DMU 60
5 axis clamp turns on after I try to turn on the machine, then a second after, machine turns off and bunch of errors pop up.
The most important one, which I'm looking for help from here, is the next one
PLC00829 ERROR 5th axis clamp not released
Does anyone know how to fix this problem?
Ive attached a picture of the issue
Here's a video of the problem:
MP 4110.16 : 1 ;Überwachungszeit V.Achse Klemmung auf/zu (Monitoring time V [B_Axis]. axis clamping open/close )
Change this parameter from 1 to 2, if the problem persist then you need to check the pressure on the pressure switch / sensor or check the clamp itself. Or contact your "service agency". Hope this helps.
