kustomizingkid
- Aug 2, 2010
- Minnesota
And who defined that? Your local diesel shop or some Youtube expert?
O-rings don't belong in a work truck. If it's a toy go for it. If it needs to be reliable and repairable O-ringed heads are a very stupid investment.
The absolute stupidest approach is to O-ring the heads while still running the stock profile camshaft. If you do that you have a fundamental misunderstanding of what's at work here.
And like was mentioned before several times, the surface finishes of the block and head deck surfaces are critical. The surface finishes they are made with do not work. They will fail even with studs. You have to pull the engine block out, surface the deck correctly. Correct surface finish does more for reliability than O-rings ever could.
Then there's the valvetrain stuff. Just in this thread there are several first hand accounts of 6.0 lifter failures from the plastic guides.
What RA is the correct surface finish? The stippled Mahle head gaskets are a gamechanger too...
