How much pressure are you running? Any way redesign to use airbags instead of a cylinder? Could be 25% of the cost.
This 8” bag has 10” of stroke and is $120:
The cylinders I use are rated for 250PSI, but I only have 2 customers that run the machines at that pressure. Running the cylinders at 250PSI has some challenges so most people opt out of that pressure range and stick to 40-150PSI from standard shop compressors.How much pressure are you running? Any way redesign to use airbags instead of a cylinder? Could be 25% of the cost.
Nope, not at all.largest cost at the moment for building my own cylinders is the cost to have a local shop make me the pistons and thread the cylinder rod on a CNC lathe, am I crazy to interpolate the pistons on my HAAS haha!!??
I don’t know exactly what your machine looks like. A bag would be single acting, what do you use the return for? A ram return function or stripping would require a lot less force and could use a much smaller commodity cylinder vs a 6” bore one. The force would be linear, they design them so they extend upward vs ballooning outward.The cylinders I use are rated for 250PSI, but I only have 2 customers that run the machines at that pressure. Running the cylinders at 250PSI has some challenges so most people opt out of that pressure range and stick to 40-150PSI from standard shop compressors.
There is a company, I think out of business now, called PNEUCO. They made a pneumatic press brake using an airbag/bladder. I looked into it when I was designing my first couple prototypes but never took a shot at designing a machine using air bags. I have never used one... Without a piston I would guess the force would be non linear, and they would have no possibility of being double acting?? They sure are cheap though... Might be worth a shot at designing a machine that can overcome the challenges of using an air bag.
Have you ever seen or used one in a pressing application?
Apparently the OP will NOT post a pix or two of said machine.....I don’t know exactly what your machine looks like. A bag would be single acting, what do you use the return for? A ram return function or stripping would require a lot less force and could use a much smaller commodity cylinder vs a 6” bore one. The force would be linear, they design them so they extend upward vs ballooning outward.
Notice
