7.5hp baldor, 184tc, 208-230/460, wired for low voltage. 3450rpm.
I am attempting to build an RPC for an older '42 MG 10ee. I am just going to manually start the motor, so no starting capacitors necessary.
I've been following the Fitch design, by way of balancing the Run capacitors, but am having an issue. I have an assortment of 7.5, 25, and 55mfd capacitors. Unlike what Fitch claims, adding caps to the a(line1)-c(generated leg) raises my Vbc more than the Vac.
My motor (with no load) shows Vab 246, vac 231, vbc 233.
At cp55mfd cs25mfd, vac 248, vbc 247.
Once I begin using different combinations of mfd on Cp and Cs, vbc seems to increase faster than vac until I'm around 265vbc.
I can get the voltage within ~4-5v difference between vac and vbc with several combinations through the range. I worry that the only way to test this with a load is to plug in my 10ee, which is a pretty expensive system to fix if something gets fried. Is this something that warrants concern, or should I just plug it in and see what happens with the voltage so I can get these balanced properly?
