metalmagpie
- May 22, 2006
- Seattle
We all use compressed air. So do I. I've wanted to upgrade my compressor for awhile. I found a donor compressor which was someone else's uncompleted project and bought it. It's got a Champion R30A air pump (4 piston, disc valves, splash lubricated), 7.5hp motor, Square D pressure switch, and a 120 gallon horizontal tank.
I am in the midst of going through the air pump. I straightened the ribs on the intercooler tubes, bought new air filters, cleaned and relapped the valves, and removed the tubing between the pump and the tank to rethink it and refurbish it. I also tested the motor and am in the process of hydrotesting the cylinder.
My game plan has multiple possible pathways. If the tank tests good I'm going to just build it into a compressor. If it doesn't, I plan to remove the air pump and 5hp single phase motor from my existing vertical compressor (80 gallon vertical tank) and install the bigger air pump and motor up there. That would probably involve extending the top plate.
Along the way, I plan to pipe in a heavy duty oil cooler between the pump and tank, with a filter between the cooler and tank to trap water.
The rest is just details. But I have a lot of little problems to solve. For example, Champion compressors have a check valve where the air enters the tank, as is common among many compressors. This guy just screwed pipe into the tank to a vertical T. An overload valve is on the top part of the T. Going sideways from the T is a freestanding check valve of the type I never would have guessed would hold air. Then on up to the air pump. Have you ever seen a freestanding aftermarket check valve on an air compressor before? That bit of plumbing was rusty and looked pretty bad but after I took everything apart and wire brushed it and put it back together it doesn't look half bad. I took apart the check valve and extracted the disk. I lapped the disk and cleaned its seat, but it sure doesn't look like new. I can't really imagine it wouldn't leak.
More later.
metalmagpie
More later.
metalmagpie
