But that's not where the oil needs to go. It needs to go in the ACME nut.
I guess that from your picture, you oil the ACME nut by shooting oil up from below.
Yes, of course I know...that's what I/we have been saying for 2 pages of threads!
The purpose of the photos above was only to illustrate the only other ways that someone
could possibly get some oil on the ACME threads if they stick with the same non-drilled OEM
nut that is either already in their machine or a repop that they recently installed.
(Or is this how SB expected you to do it).
Clearly what needs to happen is that the manufacture(s) of these specific replacement nuts need
to at least start offering the drilled-thru option, and to help educate the owners of both
9" and 10" machines of this need for lube at the threads. Otherwise they will just install the same old
closed style without giving it any thought as hundreds have done in the past.
And with all due respect, I personally think a 1/32 hole is far too small to try to drill thru a thread wall.
The chance of a broken bit is fairly high. I don't think there is enough room for the nut to act like a
"reservoir". A 16th might be as small as I'd go, anything smaller stands a good chance of getting plugged up.
And besides, an open hole is just going to drip the reservoir dry anyway overnight.
I drilled a 1/8th in mine, and I get the flow I like as I crank the handle throughout the travel.
Just saying.
PMc
