That's a Hyatt bearing. Ford used them but I doubt they invented them. They aren't very good and are best replaced with modern roller bearings where it's possible. My car had them in the rear axle or either side of the differential. In practice they often galled the shaft they ran on. I've seen an axle shaft worn 1/4" deep. In some cases, a hardened sleeve was pressed onto the shaft. This was better, but they were still very "loose" by any realistic standard.
The SAE specs for materials were fairly specific and well thought out before WWI. I generally use PM Heldt's 2-volume manual on automobile design (1912 edition) as a guide. When I first read it, I was surprised at how advanced the engineering data was. When inferior materials were used, it was only to save money...they understood very well what the best available was.
