Hey gents,
Ive got a Adcock Shipley 2s milling machine for a while. It hard to change gears and always get grinding. Seems like the gear changer wheel isnt synchronized well with the sproket positions inside the gearbox. Also the turtle/rabbit control for high/low speeds gave out and went past its positioning point.
Id like to repair this but i dont know where to start.
The rapid travers would sometimes work and sometimes not. Lately it got stuck in rapid even if i only ran regular travers. All these problems have been present for a long time. They just gradualy got worse.
Also, most of copper oil tubes are intact, but one exit is with a rubber/plastic hose. Its attached with a hose clamp and id like to replace it with copper and aim it in the right area(i have no clue but guess in the vicinity of the existing hose) also found a broken set screw on the gear of the y axis, although no problems there.
I dont know where to start so here are some pictures.
