I'd like to add a wash down gun to our new DMG Mori NLX lathe, I got a $4000 quote for the factory setup so think I can figure out something diy.
I'm thinking adding a pump will be the best thing but open to ideas. I've read of many guys adding a three way valve, been awhile since I tried but I believe it won't let you run the coolant with the door open without holding the idiot button on the side of the control. Bypassing the door overrides is not going to happen at our company either.
I've also seen guys put a switch to the pump contactor to turn the pump on without going through the control. This would be another option but not sure we're comfortable messing around with a brand new machine.
So if we add a pump, how big is big enough? I don't have much to compare to, our Haas mills have 3/4 hp pumps. The one has a 3/8 wash down hose and the other a 1/2", the extra flow is noticeable with the 1/2" but really the 3/8 is plenty. So I'm thinking either one is probably restricting some flow.
Would a 1/2 hp pump be enough? Not much more to get a 3/4 but don't want to go overboard.
Any suggestions on brand/type? The grundfos pumps I'm looking have a bronze or composite impeller, my hunch is to stay away from the bronze as our coolant turns smirf blue when exposed to brass/copper/bronze.
Thanks!
Thanks!
