Adding thread dial to 9" Junior?
Mike C5
Apr 26, 2022
I have a 1933 vintage 9" (Junior or Heavy as I understand it) and would like to try learning to cut screw threads with it. I have change gears but still haven't acquired a thread dial yet. I notice that most of the thread dials attach with a pin into a boss on the edge of the cross feed saddle. My machine has no such provision. I also see some dials with a flat flange which includes two mount holes in it. Either way it appears I will have to drill some holes... Or did this machine have some other way of attaching a thread dial? Is there a bracket I'm missing (probably rare & expensive)?
Here some photos of the lathe and saddle. I would much appreciate any advice on how best to proceed.
Mike C5
Apr 26, 2022
Thanks John,
That's interesting that it has a bracket cast as part of the dial body parallel to the edge of saddle. I get the feeling that isn't a very common configuration. Looks like I'm going to have to improvise....
I did some more searching and found this but I'm not sure the saddle is thick enough to support the pin properly.
johnoder
Jul 16, 2004
Houston, TX USA
Before I left my rather drippy "cellar" in Coventry CT in 1971 I fixed up my 1923 13" with a home made thread dial that included a hard maple "gear". None of this lash up had the least idea it was inadequate - it just let the old SB cut all sorts of threads
Mike C5
Apr 26, 2022
I can imagine hard maple making a good gear for this application. No doubt it would be a fun project but I think I'm going to go with one of the 3D printed ones for now. This one has the bracket that looks like the one in the 1931 catalog.
Mike C5
Apr 26, 2022
Those of you who have a 9" Junior with thread dial attached as shown. Is the stud and pin arrangement like the photo below how yours is attached? I drew up the basic dimensions of this area in AutoCad and would much appreciate if I could get some feed back on where to place the holes and what size threads.
Mike C5
Apr 26, 2022
Come on guys, someone here must have a machine with dial as originally installed. This catalog screen shot seems to show a bolt. Is there a permanently mounted pin (on apron) in lower hole of bracket?
SWIGIN
Feb 11, 2009
PA
On my 1922 O series I didn't want to drill a new hole, so I made a bracket off the half nut bolts.
I have pictures on here somewhere, but I have no idea how to find them.
