Advice needed
Status
Not open for further replies.
Feb 25, 2022
I'm not a machinist by trade, but I'm wanting to start doing some automotive machining for myself and friends and maybe grow it into a side job. The only engines I will be messing with are pickup truck cummins, 5.9 and 6.7. I want to be able to surface heads and blocks drill head stud and main studs for larger fasteners and bore cylinders. My question is would a vertical bed mill machine be plenty rigid enough for surfacing, where I have to have less than .001 variance preferably within .0005 over 30 inches? My thought is if i can buy a bed mill I can use it for surfacing, boring cylinders and drilling, plus use it like a smaller knee mill thus utilizing it's versatility. The machines I'm looking at are used ones like dpm trak rx7, fryer mb14q and the like with stationary beds that move in x and y axis but the column moves in the z. They weigh 6-8k lbs. The other option would be buy a dedicated surfacer, which would be 15-20k and have only one use and buy additional machines for boring etc. the bare blocks weigh 325 lbs. these machines are rated for 1500 or so lbs. but I need it to be as rigid as a dedicated surfacer. the blocks are 14 inch wide at widest, 17 inches tall and 30 inches long. thanks
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
Poor title go back and change while you can..Advanced edit, and then click on the title to change it.
Advice on automotive engine Service/ Repair.
Might be an OK title.
Or the whole thread is just Hens Chatter, that nobody can search.
I might have some input but won't input to a poor title thread.
gustafson
Sep 4, 2002
People's Republic
YOu need to have a useful title
They make specialty equipment to surface heads.
I seriously doubt you need[or can measure] that amount of accuracy
Heads need to be pretty flat across the short dimension, maybe within a thou across that. Flatness the long way is not so vital.
Nothing needs to be within half a thou
Status
