Hi All!
Looking for some advice.
I may have the opportunity for a lathe that is 440/480v three phase only with a two speed 7.5 hp motor. Full load current around 10.5 amps.
I don’t have three phase or 440/480 power and am wondering what my options are and if they are affordable enough to purchase the lathe when the lathe comes available (shop is ‘planning’ an upgrade).
I have searched on the forum and found some helpful and interesting information but I’m not sure if I have everything straight piecing it together from the different threads.
I have 240V single phase available. Closest/easiest source is a 100 amp subpanel within about 30ft (probably about 50ft wire run). My initial thoughts were to either build or buy a 10hp rotary phase converter but when using a 7.5 hp lathe as a load in a couple of the commercial RPC manufacturer’s calculators, it specs out a 15 hp RPC. Only the lathe would be run off the RPC. So in your experience would the 10hp be undersized?
Since a transformer would also be needed, I don’t know how the demands or losses of that might affect the size of the RPC required or the specific size and specs. of a transformer. A simple calculation of 480vx10.5A= 5040va x 1.732 = 8,729 but I don’t know how much ‘extra’ capacity might be needed for startup loads. My initial thought was 15kva.
Looking at the used market for transformers most of what I see are step down and may be able to be reversed but many I see are 480delta/208wye.
I have seen a couple of new ones that are 240v step up to 480wye…close to $2k. Does it sound like something along those lines is my best bet?
Thanks,
John
Thanks,
John
