So... Before you jump to any conclusions, it is best that one has a solid understanding of just how an unloader is supposed to operate, and why.
An improperly operating, or dysfunctional unloader, can make a perfectly good compressor and/or motor look bad. It can burn out contactors, trip breakers, and send your teenage daughter home with an embarrasing social disease.
there's several different types of unloaders, before assuming an operation scheme, it's important to determine what type of unloader. It's also important to recognize where the unloader discharges from, and to, and where the check valves are that backstop air to protect the unloaded volume.
There's unloaders that operate in cyclic duty... meaning, when target pressure is reached, they shut off the motor, and vent the compressor's outlet volume... then there's continous-duty, which do the same, but keep the motor running.
The former is the most common you'll see in a typical home or commercial shop environment... the latter is frequently found in industrial or prime-mover applications. The former is obvious, the latter is most often used when either stopping the driving source is either impossible, impractical, or subjects the motor to excessive starting and stoppling under high load. A diesel-electric locomotive or a tugboat is an excellent example where continuous running makes most sense, but it is also used in high-demand electrically-driven units where the electric motor would be subjected to a higher number of starts-per-hour that the manufacturer rated the motor. (Starting causes high inrush currents, thus considerable heat... so excessive starting cycles can overheat a motor, whereas, simply unloading the motor and allowing it to spin free helps cool it between loading cycles).
There are unloading systems that can do BOTH, the only difference being some componentry that makes the decision whether it is appropriate to shut down the prime mover.
So WHAT does an 'unloader' really do?
Every PROPER compressor has unloading, and the purpose of unloading is threefold:
First, to prevent the compressor from having to start up under full head pressure... i.e., with high pressure air already against the piston (or scrolls). This stalls the compressor, and leaks past the seals, blowing them (and oil) out into places oil is not supposed to be.
Second, to prevent the compressor valves from being captivated as a result of head pressure. Some inexpensive compressors use the cylinder's outlet valve as the ONLY check valve between pump and tank. This means the tank's full pressure bears against the outlet valve immediately amidst the first rotation. IF the valve is held down tight, the very first compression stroke will stall the compressor, if not by simple pressure, it will hydraulically lock from condensation (occupying compression volume) and an outlet valve that has been rather firmly seated by full tank pressure downstream.
Finally, it allows a series of rotations for the motor to get up to speed BEFORE the pump builds any significant workload. The pressurized flow leaves the compressor's last outlet valve, travels THROUGH a tube which is frequently covered with fins (aftercooler), which then feeds through the tank check-valve, and into the tank. This volume gets discharged on unloader actions, so that once the unit has been engaged in a restart, it will take several rotations BEFORE the compressor's last stage has brought up that volume up to high enough pressure to constitute a working load.
Aside from conveying compressed air from the last compressor stage into the tank, this volume also cools the compressed air. Combined gas law says that all the thermal energy in a given volume of air, will be packed into a smaller space when that air is compressed, and the end result of more thermal energy in a smaller area, is heat. That air coming out WILL be hot. Running it through that tube, especially if it has cooling fins integrated into it's exterior, will COOL that compressed air, allowing it to stabilize in density. It ALSO means that moisture in that air will condense and precipitate out, which is necessary evil in obtaining 'dry air'. That condensate will USUALLY depart into the main reservoir, where a drain valve at the bottom will discharge moisture at regular intervals (we hope, right?) Why would that matter? Well, if you've got an aftercooler tube that's three-fourths full of water, that means only a fourth of it's volume is available for AIR.
The difference between a gas, and a liquid... is that liquids aren't compressible... gases are.
Pneumatic systems that are full of water, are called "Hydraulic systems". Hydraulic systems that are full of gasses are called "Pneumatic". Best to keep Hydraulics and Pneumatics well-separated, as once circumstance results in fast moving objects coming to a very immediate and traumatic stop, while the other results in devices becoming diesel engines.
In an intermittant system, when the pressure switch's upper temperature is met, three things happen:
1) Motor power is cut off
2) A valve is opened which discharges all pressure between the TANK check valve, and the compressor's last outlet check valvej
3) Any MOISTURE in that volume, gets evacuated.
Compressors have a line between the last stage's outlet valve, and the tank.... and it is THIS volume that is discharged upon shutdown. It seats the tank check valve, and relieves pressure against the last stage outlet, and in doing so, any prior stages are also relieved. This means that, when that motor stops, you'll hear a puff-hiss (which is the aftercooler line being evacuated.
When it's time to restart, the contacts of the switch snap shut, and at the same time, the unloader valve pin is released (sealing off the aftercooler volume's discharge), and the pump starts spinning. It takes three-four turns of the pump before that aftercooler volume reaches any significant pressure, and by THEN, the AC motor has gotten up to a high-enough operating speed (let's say, to within 10% of it's rated speed) to be 1) Well below it's start surge current, and 2) capable of developing a useable torque for the compressor's need.
Make certain that the unloader is set up right. If it's a simple unloader, the pressure switch that controls the system will also have a little valve of some sort... frequently it'll look like a schraeder valve, and a lever arm coming off the switch operator will depress the center pin when in an unloaded state. If that isn't operating, OR someone has crimped, disconnected and blocked off, etc., the line, or replaced the original tank check valve (because the tank check valve is often an integral component to the unloader's operation), then there's a very high likelyhood that your compressor will just not operate right... and an equally, if not higher likelyhood that you'll replace darned-near-everything-else thinkin' that they're all bad, when it's just part of the unloader that isn't operating properly.
