I hear alot to
not use pvc, but we have pvc air lines here, and the other place I worked part time. I think this shop has been here for about 4-5 years and no "blowouts" that I know of....
I think not using pvc is a little thing, use whatever IMO. But yes, put a drop for a water trap/catch or whatever they call it.
"I've played Russian Roulette 3 or 4 times. Never had any problem. I'd say you're ok to play Russian Roulette"
Your logic fails several tests of logic, one of which is the n=1 problem. You are only looking at one data point (your shop). When a lot of shops are considered, its clear that there's a pretty good risk of catastrophic piping failure (PVC fails in catastrophic mode: you don't get a a warning, everything is fine and normal, and then suddenly there's a 5 inch shard of pipe through your eye). As Mud points out, "It works great until it doesn't". PVC and CPVC are fine for moderate pressure (e.g. water system) incompressible liquid service. For higher pressures of air systems, given that air is compressible, the air in the line contains too much energy and PVC and CPVC are unsafe. Using either is essentially a third-world, short-cut oriented, "Who cares if the workers are injured" approach.
Quincy knows a bit about air piping. They do sell their own air line product, but their site has this to say:
"You can’t use just any plastic pipes for compressed air distribution. The most common types of plastic pipe available today are polyvinyl chloride (PVC) and chlorinated polyvinyl chloride (CPVC).
These are widely used for plumbing applications but are not suitable for high-pressure systems, such as compressed air channels, because they cannot withstand the pressure.
Acrylonitrile butadiene styrene (ABS) is a good material for piping compressed air. You can find ABS in a variety of products, from car fenders to Lego brand toy bricks. Polyethylene (PE) piping is also produced specifically for compressed air systems. Another suitable plastic for compressed air pipes is high-density polyethylene (HDPE).
The early attempts to use PVC and CPVC caused a number of catastrophes, resulting in the Occupational Safety and Health Administration (OSHA) banning them for use in high-pressure systems. However, ABS, PE and HDPE are all OSHA-approved for compressed air piping."
The "PVC pipe has been safe so far" reminds me of:
"Every Friday for 20 years I've had 5 or 10 beers and some shots with the boys and have driven the 15 miles home from the bar without incident. Go ahead and do this IMO"
"I've smoked in bed for 50 years of my adult life and have never had a problem. Go ahead and do this IMO"
"I've had sex with hundreds of different people, without protection, and never had a really serious venereal disease. Go ahead and do this IMO".
There's a reason why OSHA banned PVC and CPVC for air lines. Guys that have seen PVC failures (Mud, johfoster) won't get near it. No one should.
