airc heliwelder 250 and a s-54e wire feeder
jwshanks
Mar 19, 2023
I was wondering if I can run this wire feeder on my Arico welder. It came with a Hobart rc-256 that is 3 phase. As I don't have 3 phase I would like to use the airco which is single phase. I have seen the threads to convert the Hobart to single phase in here. If I have to convert it, is there a detailed break down on how to do it?
DDoug
Oct 18, 2005
NW Pa
The answer is no.
Philabuster
Jul 12, 2006
Tempe, AZ
The Miller S-54E is just a 115 volt wire feeder. Your Airco welder is not really designed as a general use welding power source, but no harm in trying to MIG weld with it. Just make sure you have the polarity of the gun set correctly.
mmarquette
Dec 20, 2016
So many cheap welders out there . Find a Miller that will run the feeder . In my opinion, it’ll be a whole lot easier to do.
dana gear
Feb 27, 2013
Northern califorina, usa
Your Hobart is a constant voltage power source for the GMAW/FCAW process (wire welding)
it will have 120 AC output for the hobart feeder that it was intended for. That said you can hybrid your Miller 54 to the hobart without much problems, works this way, you pull your gun trigger that controls/energizes the wire drive motor as well as the shelding gas solenoid and a control signal is sent to the power source to close the weld contactor. Your going to need a wiring diagram from both to come up with the hybird control to correctly interface the two. You may want to pick up a old Hobart model 27-4300 feeder that will plug right in, there pretty cheap. Your Miller 54 could have a hubble twist lock or a Amprinol plug, Hubble is old world Miller, Amprinol is the later. You could pick up a older Miller single phase C.V power source and if in the last 20 years will be a direct plug in with the Amprinol early will be hubble. My opinion is your opening up a can of worms trying to change a 3 Phase Hobart to single.
