Froneck
- Dec 4, 2010
- McClure, PA 17059
I have a few CXA Aloris Tool Post, a CA and Dorian E too.
On a few occasions I noticed the tool post moved (rotated) after a heavy feed and cut depth, the CA too. Wanting to complete a rush job of quite a few parts I didn't want the tool post to move so I tighten it well, very tight! It didn't move, later I wanted to change the angle and trying to loosen the clamp nut, the center post of the tool holder was turning too. I pulled it tight again and moved the compound. I will finish the job today so will loosen the tool post and do what is necessary to fix the issue. I'm thinking the reason for "rotating" may have been the center post. I've disassembled Aloris tool post and know how they work. Should I loctite the lower thread inside the tool post that the center "tube" is attached? Would putting a needle bearing thrust bearing between the center post and hold down nut be a good idea?
