dgfoster
- Jun 14, 2008
- Bellingham, WA
Yes, that is so. However... With the top of the compound in good contact, a good fit on the t-nut and 4 or 5" of steel on top it isn't likely to flex much. Doesn't take a lot though if you're pushing the machine a bit.. I would not as the relief unless necessary, but that's just me.
I will submit that it is true that the tool post will cinch up if the compound is flat and the tool post is flat. But it cinches up more easily and more securely if centrally relieved.
I’ll grant you that the relatively tall column of the tool post probably does not deflect that much though steel is simply rubber in disguise. However the top of the compound is not nearly so thick and is also made of rubber—-cast iron rubber, but elastic material nevertheless. If you consider how the top and to a lesser extent the tool post, being elastic, have to deflect under load, getting the load bearing points distributed radially improves their ability to resist rotation substantially. I have tested this out in practice and will submit the difference is significant. I also know of one other case where a friend followed this advice and found a big difference. The amount of torque needed to cinch up the post reliably was about 1/3 that of an unrelieved post.
There is room for both opinions as there should be. Just trying to flesh out the reasoning behind my suggestion.
FWIW,
Denis
