Rock6.3
- Jul 7, 2010
- Northern California
I would like to identify a suitable boring insert for my 16 IR internal indexable tool holder.
I have a Shars 404-2291 internal indexable tool holder, but I do not have an insert for boring the ID to size before I begin using the threading insert.
The Threading Insert is a 16 IR, and Shars claims that no other insert will fit.
My generic el-cheapo Harbor Freight triangular inserts appear to fit, naturally they are devoid of any identifying markings and are dull as rocks.
I'd like to acquire a few triangular inserts I could use for boring mild steel. I am not looking for donations, I'm seeking information about alternative inserts that would fit this tool holder.
What I know:
16 IR: .146" thick 3/8" inscribed circle, or in metric: IC=9.52 INSL=16.49
What I don't know: Which standard triangular insert should I be looking for?
Using the chart at http://www.carbidedepot.com/formulas-insert-d.htm
Theory: TNMG332 ??
T-Triangular
N-Zero degree clearance ?
M-Tolerance ?
G-ChipBreaker yes double sided cylindrical
3-Inscribed circle size 3/8
3-Thickness .187
2-Radius .031
More details: I'll be boring 5/8ths inch steel plate 2.2" inside diameter, on a 12" Atlas lathe. I do not have a HSS boring bar.
What I know:
Theory: TNMG332 ??
T-Triangular
M-Tolerance ?
3-Thickness .187
2-Radius .031
