Webley91
- Feb 13, 2009
- London, England
Looking into it further, I have found a site that lists a bore dimension for "mounting roller bearings" as 36.89 to 36.98mm. "For torque transfer" is given as 36.67 to 36.75mm.
That is over 1mm larger than given by the other source. I had assumed that these rings were made to standard sizes?
The second site also says they can compensate for misalignment. Does that mean that, depending on the amount of wear, they could be used without needing to bore out the housing?
