escapethewrmhole
- Dec 10, 2017
Only if you haven't tried DLC.ZrN seems to be all the rage for aluminum coatings these days.
I have been having incredible success with either these OSG products:
Can confirm DLC is the best IMO for aluminum, roughing or finishing. I've been having really good luck running GWS alumigators with their DLC coating, I also get my Mitsubishi AXD inserts in the DLC coated version and they last forever.Only if you haven't tried DLC.
A Brand AE-VTS-N
A Brand AE-TL-N
The VTS is the "premium" line and comes at roughly double the price of the TL.
yes that was my other option of ordering new end mills in a 2 flute, had a regular coated 2 flute but seen the aluminum sheen on it after one part and BUE was bad on it. cut with more chatter then i was liking overall and had to drop rpms down to about 2200 and 8 or so ipm.
had my tooling rep in and he was going to ask a local shop what they had been doing, said they were running dry on aluminum but wasn't sure what grade.
10K, just had issues with it vibrating the part in the slot, is why its so slow. its about 50% of recommended rpms and was playing around with ipm from 8 - 19, fastest it liked was about 12.5What is the max rpm for your mill? A 3/8 end mill in aluminum running at 2200 rpm is extremely slow.
I will have to try the WD and see if it makes a difference. hopefully it doesn't stain aluminum like some coolants i have used.YG alupower 3 flute 37 degree helix diamond coated carbide endmills are where the money is at.
Use WD-40 mist if you cant run flood
even standing there with a spray can of WD-40 will be way better than running dry
Are you turning your coolant off before the tool change with an M9? If so, don't. My coolant is on the tool halfway between the tool change height and the part if I let the machine deal with the coolant off and on for tool changes.On looking, the coolant doesn't switch on before the tool hits the part for the first hole (Speedios are fast...).
Notice
