LUX93
- May 20, 2015
- Lake Havasu City
I have had some issues in the past with aluminum hard spots that appear when the surface finish is smooth enough. I have seen it in round stock appear as spotting, it almost looks like leopard spots. I think I'm having a similar issue with some bar stock, I'm seeing lines through the material when we flycut the face. The deeper we went the more lines appeared, just closer together. I can hide it using a face mill, but these parts require a very smooth flat surface, and the face mills you can feel an ever so slight hump when you run your finger across. It's barely anything, with an indicator it moves maybe a couple tenths but it's enough to not be acceptable for the application, hence the fly cutting. The stock it 7" wide and 10" long, 6061-T6, from Kaiser who usually produces some of the most consistent aluminum we've had.
