rons
- Mar 5, 2009
- California, USA
Finished my DTV antenna yesterday.
I would like to replace the steel mast with a aluminum mast but don't want to use a through hole. Something that clamps on.
Was thinking about building a second array and double stacking the pole. Either pointing the existing one at 320 degrees and the second one at 22 degrees.
Or pointing them at the same transmitter and adding to the gain.
The Allen bolt is 10-32 and the hex shank is 3.5" long. There are two hex shanks at the backside of the array. One at the top and one at the bottom.
I desire the connection to be detachable with the 10-32 bolt secure into the hex shank. What design or part exists that can clamp on to a thin tube
that is 1" diameter and hold a hex shank. A wrap around strap with only one bolt maybe.
In the picture are a couple of U bolts and a 1.5" steel pole. The white insulators are fiberglass rod.
I approve of this.
http://www.worldscientificnews.com/wp-content/uploads/2016/06/WSN-56-2016-21-32.pdf
I asked this question when I thought about those discarded aluminum scooters that get discarded by spoiled kids.
The handle bar height adjustment is tightened with a cam-lock lever. I was thinking about something like that.
I approve of this.
